Bougeant
- matrix reloaded cam
technomate tm 5500ci plus
80 cm dish
art card
- newcastle
Hi
This is my first post so please treat me gently!!!
I had been happily using Tps (until all went pear shaped)to watch French tv and English Football.
Due to the code changed i have just bought an ART card.
I have a Technomate TM-5500CI Plus,80cm dish and am using a Matrix Relaoded Cam.
When i put the Art card in the cam,then the cam into the technomate it states that the channel is scrambled so its not unlocking it.
What do you guys think the problem is?Is it the cam?If so what do you reccomend?
If it is the cam is it worthwhile buying a new cam or a new receiver??
I hope that you can help and thanks in advance
Bougeant
Bougeant
