Relook problem
wannabee
Vu+ Duo with 1TB HDD, Vu+ Solo with 500GB HDD, Dm7025 with 80GB HDD & 1m Triax
Advent 9415 lappy
Co. Tyrone
Hi..
My best pal has a relook 400s reciever
He is using a ccam 1.7.0. The image is fantasy with 2.13.6-neumo
This reciever has a dual tuner and thats why he is using this image..
Is there a newer image that can be used on this reciever which will allow him to update his cccam as he is getting alot of freezing on all sats..
Any help would be greatly appreicated,,
Steve
I have mine running on enigma now but you loose 1 of the tuners. Support stopped for DGS images after CCcam 2.0.0. Anything later gives freezes every 10 seconds or so.
He will need to flash it with an "All" image which will have the correct bootloader, if he uses one of the "noboot" images going from DGS he will have an endless bootloop.
I used the AbCom enigma on mine for about a year and its very stable, but I have been using the latest SifTeam image now for about a month as it has both cardreaders enabled. Its pretty stable too. And all the latest cams and configs on the server for direct download to the box.
Thanks for reply Tom..
Are you still able to use the dual tuner with this..??
I mean are you able to record one thing and watch another.. ??
Thanks again..
Steve
Thanks again..
Steve
No.U are not,running on enigma u loose 1 of the tuners.
