Remote for uniden ust771 positioner
wium
C and Ku
South Africa
I am looking for a remote to use with my Uniden UST 771 positioner.
Hello!
Wium,please can you post a picture,of the remote you looking for?
i loock on my dual tuner uniden sq 590 that weights 10 kg,there are included 2 remote,but not that type you looking for,looks like every modell,has a diffrent remote..
Turok unfortunately i do not have a camera.
I also have a UST 881 positioner with which i am using an UST 689 remote.The 689 will not work on the 771.You are right it would seem that each unit has its own remote.
Hello!
yes thats very strange,normaly,between the same brands and modells the remote sensor should be compatible, i dont know,why uniden make it diffrent..
here another picture of a remote!
220462312905 ebay item nr!
you can buy there all together for 19€,when you would not find a remote!
Turok said:
Hello!
I helped write the manual for that model (back in 1995).
It was Uniden's last stand at the domestic satellite market, a bit of a white elephant as there was no further development on the firmware.
Is it still working ?
Yes i know channel hopper,you alrady told me this,in a older pst,and i remember:)
very good manual indead:)
i have it also here,you write the manual for all modells?
on the 590 q modell i have a lnb setting that calles Esc what does this means?
i use also a dual axis uniden receiver and that one you see on the picuture,i have to read in manual for what is the small 2.remote for,currencly i dont know,bought this one very cheap in a local technical market!
now its time to play withit,so long untll the swich off the analouge signal,i enjoy the good signal quality every day!
maybe iam crazy,when i collect analogue receivers like montery 40 /140 and the uniden series,i dont know:)
but because we living in the old days,we cannot forget them,in your mind,how it was before the digital age,that promise us better picture quality,and dont say any word,about high comrpresion and artefacts,after fast movments!
Only that one for the Uniden company, and then moved onto a number of Korean digital models for a couple of years.
I can't remember what 'Esc' stood for, are you sure it is not just to get back out of the menu ?
Hello!
good morning,does uniden also made some digital reiceivers?
i also like the radio scanner from uniden.)
when uniden stop the production,same time then drake?
i ask my colleague in the nabour villiage he means ecs ,stands for eutelsat comunication satellite:)
yesterday i try with the uniden to set up astra with the 2,20m dish without motor,show me a signal strenth of 510 on the zdf transponder,can i use this value,also in the digital age!
sorry for many qestions,when its to much discusion here,i can send a pm also!
