rudream
H
homerjay
Spiderbox 9000HD, Super DARK MOTOR, 80cm Dish, SKY+ HD, HTPC w/7MC
Chorley, Lancs
right seeing as hydra is no more ive moved over to rudream.
got all my sats and channels back on, only problem is i cant manage to get any emus and keys working.
ive downloaded from the menu newcamd and latest keys and ive set the channels to use the correct cam and the keys are definatly there but to no avail.
oh and i had to change the download server to the 2nd in the list as the 1st did not work.
what am i doing wrong?
cheers
I'm still sticking with the Hydra as a multiboot at the moment, there are in my opinion no better images with regard to EMU and key update.
Have loaded 1.09 CVS into main flash just as a solid base and have Phoenix and Kangaroo in USB.
PS. Would't be surprised if the Hydra grew another head. ;)
BGonaSTICK
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Exactly. It's likely to work for a long time yet anyway with a bit of manual tinkering. :)
gameboy
gameboy
Ding Dang Doo
Scotland
They only said they would no longer update the control panel - not that they wouldn't produce any more images - here's hoping anyway.
There's more than one way to skin a cat (sorry animal lovers).
I wonder if the applications for FTV cards have increased?
H
homerjay
Chorley, Lancs
thanks guys, but i like to break things and explore new avenues, so ive already got rudream on as an image, any idea's what my problem is, (ignoring any mental issues of course :))
BGonaSTICK
BGonaSTICK
Brighton
LOL. Mental is a pre-requisite... ;)
I'm glad you're fiddling, it's very healthy and I'm not not trying to discourage you, I'm just making the point that people shouldn't panic.
Re. your problem, it could be many things. RUDream images use a slightly different method of implementing emu's and keys. You need a different flavour update.
Get yourself over to Toes or Sat-Ind. Spartan has an update pack that does what you want. :)
It's clearly labelled 'RUDream' IIRC.
H
homerjay
Chorley, Lancs
panic? me? never? but i am gettin married in a week, could be sommit to do with it...
i've tried spartans, but i dint notice an RUDeam pack, but i'll check again.
cheers
edit: found it now, although toe's is very 7000 orientated and i have a 5620. are the emu's the same?
BGonaSTICK
BGonaSTICK
Brighton
cheers
I believe the emus are identical, but can't swear to it, as I have the 7000.
I just went looking for it for you, and couldn't find it! O-Ha
Good luck on your big day!!!!
T
tux233
RuMulator102 emu pack installed on NFS is working for me on a DM5620.
H
homerjay
Chorley, Lancs
cheers tux233, but i tried gemini instead and the worked a treat no messing :)
BGonaSTICK
BGonaSTICK
Brighton
Gemini is to Dreambox as butter is to hot toast.
P
PCD
DB Magician
Manual instal of emu with rudream is very simple. Download from cysat.net, unzip, rename eg scam.tar.gz, ftp to /tmp, in DB settings - addon manager- manual install.
S
samedin
Sky Dish
Dreambox 7000s,
Dreambox 7020s,
Dreambox 800hd
MythBackend, 2 HD Cards, Omnikey
MythFrontend 2 SD Cards
42" Flatscreen
Islington, London
I tried to install them but most of them but get complains that they are too big...do you have to have a HDD in your DB for this?
P
PCD
DB Magician
No. I have a 5620s without hdd. I downloaded scam2.5c to the pc from that site, unzipped and renamed it as tar.gz and ftp'd. Then it appeared in the manual install window in the db. I did not download directly to the db.
john_graydon
john_graydon
Dublin....Ireland
Dont want my dreambox melting...lol
