Rust on my motor
jpsr
1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
Mullingar, Ireland
I put up a 1m gibertini dish and technomate 23oo motor about 8 months ago.
I climbed up the ladder to have a look to see rust coming through on the motor bracket thats attached to the pole, and also on the bolts that were cut.
I used a wire brush on the bolts to remove rust then used 3 in 1 white lithium grease spray.
Has anyone used this to treat rust.
The grease will be a temporary protection till the sun bakes it for a bit and the weather takes the rest off, if the bolts are never to be removed again then I would use a good rusty metal primer paint on them and then something to match the mount.
In areas of high humidity or close to the coast line I would replace the bolts with stainless steel bolts, nuts and washers, but be sure to lightly lube them before mounting and tightening as some have a tendency to seize up (cheap ones) and you will then have to cut them off.
I tend to paint affected areas with Kurust, readily available from Halfords and other Motor Factors.
...and the associated website for reference _http://www.hammerite.co.uk/guide/kurust.jsp
Thanks all , will have a look.
But now you will have to de-grease it for the paint to stick.
