S Model X/ XX/ X2
raucousv
Sky X2
ksa
Greetings to all!
I have encountered problem when updating the firmware of my X2 using ver. x_223, the power lost after it was updated 100%, i tried to power switch off and on again the receiver but it will display only the running green light for about 3 secs and power lost at all. I am regularly updating the firmware of X2 for more than a year and it was done succesfully, it was the first time i experienced the problem. Was it the problem of the firmware? or the reciever power circuit board? Kindly advise to solve the problem, or any idea/help is highly appreciated.
Thanks,
raucousv
skypatch
SKY
Ankara
raucousv said:
Greetings to all!
Thanks,
raucousv
dear
you should use New loader v1.8.4 & BOOT file . then upgrade your receivers by Boot.stb & X_224 . when saw 4 green line on your receiver then press connect (IMMEDIATELY) . all files (new loader - patch - boot ) availaible in w*w.skypatch.net
raucousv
Sky X2
ksa
skypatch said:
dear
Thank you very much for the quick response, i'll try this when i reach home.
raucousv
Sky X2
ksa
It works! Thanks again skypatch.
slugworth
gsky v7
New England
Is there a newer boot file than 140 on that site?
How do they convert the boot.bin to boot.stb format?
alkiki
Skyx (the best)
Mediacom 930 i
Not so far
Hello,
I've been using 224 Firm*ware in my receiv*er Skyx but it worked 1 day only. When I read message of our friend it looks working longer??
Should I follow the same prodcedure than for X2, enter a sky boot?
I've never did it.
Thanks for your usual help
alkiki
Skyx (the best)
Mediacom 930 i
Not so far
How to helped?
What procedure should we follow?
boot_sectorz
Sky X2, Beausat 2004 FTA Plus, Echostar LT-730, twinhan Vision Plus DVB Card. 90cm Nokia Dish, 1.8m Also Manhattan 9650 Analogue
Earth......... I hope!
h**p://www.crosat.org/aploud/index.php?&direction=0&order=mod&directory=STRONG RECEIVERS has updates for Most Strong receivers and Sky X. You will find all you need here.
But I think free membership is a must for most downloads, unless those on the front page.
flex
computer
iraq
hi i need patch for skyx 2 with cam please to open tps and other
slugworth
gsky v7
New England
X240p is the last version I know of,but 1 person claimed he couldn't load it to his receiver.
boot_sectorz
The links still working hence no updates. Kindly let me know if theres anything not working so we find a way to help.
umaree67
satellite
Nigeria
Try Auto Scan from the menu and make sure you select the Desire SATELLITE. Before you start scanning.
umaree67
satellite
Nigeria
Try Auto Scan from the menu and make sure you select the Desire SATELLITE. Before you start scanning. try to see and make sure :-
- Your Dish is well align ( is luck to the satellite)
- Your Coaxial cable is properly terminated with F-connector and also connected to your Dish.
If Not
- Try no connect the cable from your satellite receiver and went to the other end for your Dish, Used DC Voltage Meter To test wether there is 14-15 voltages running on the line, if you dont have meter try to Test with your on mouse the voltage will not affect you.
see u gain
umaree67
arty8001
sky x2
france
bonjour
ou peut on trouver un nouveau firm pour le sky x2
merci d'avance
