- May 1, 1999
- Technomate 5402 HD M2 Ci, DM7000s, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Promax HD Ranger+ spectrum analyser.
- Berkshire
Thought we'd better give some guidelines on what should and shouldn't be done safety wise.
Here's a little poem, originally posted by York
York said:When putting up your dish,
Always remember this,
If the wind is blowing strong,
The time is probably wrong.
When placing on your gable,
Your ladder must be stable,
If you have a friend,
Let them hold the bottom end.
If you are alone,
Then wedge it with a brick or stone.
When working with electrical tools
Follow all the simple rules.
The manual always teaches,
To check your cable reaches.
Be careful to drop nothing from height
Or your friend at the bottom may lose his sight!
Plan the job before you begin,
And you will always win.
If you are at all in doubt,
Let the experts sort it out!
