same signal strength - variable signal quality
johnshephard
1m dish astra 28 east
free to air receiver
Crete
I have a 1 meter dish and receive Astra 28.2°E & Eurobird 28.5E south beam here in Crete. Can anyone explain to me why I get good signal strength on all channels but very different signal quality.
I use an SL65 free to air receiver
For example frequency
12441 V has 70% strength but 45% quality
11642 V has 70% strength but 55% quality
11954 H has 70% strength but 40% quality
we just had a quick burst of rain and whilst the signal strengths remained up around 70% the signal quality dropped to 25% - 30%
I understand that rain interferes with the signal and had I seen a drop in the strength a drop in quality would be understandable.
I know that I am on the edge of the footprint and do not expect great reception but it is this variation in the reception of intensity and quality which intrigues me.
Can anyone help please?
Hi John and welcome to the forum.
I'm one of those people who don't expect rain to affect the quality of my system. When this happens to anyone it's usually the setup of the dish to blame. Maybe the elevation is not quite right.
Thanks for that suggestion Jimbo, I will take another look when the weather is better.
My initial thoughts are that I’m pretty spot on. I spent quite a bit of time setting it up, in fact I spent a couple of weeks with a 30cm dish pointing it at different satellites to try and learn things.
Once I got my 1m dish in place and tightened it up 90% I moved it in each direction 4 or 5 mm virtually by stressing the bracket. Each direction the signal dropped.
I also get Arabsat on the same dish. The arabsat footprint includes Crete and has strength and quality both 70%. During the rain the arabsat signal quality did not alter. I point at Astra directly and get arabsat with an off centre LNB.
Do you have any thoughts, without rain, why different frequencies on the same satellite with the same signal strength have different signal quality?
Cheers John
Try playing with the LNB skew adjustment, this is critical on fringe reception.
