Samsung 9500 Sound....
Blackpool
On my Samsung I'm getting clicking noises on all channels. This also happens as you turn over to other channels and when you mute the sound off then on.
You can here the clicking all the time throughout the programs on all channels.
Does any one no why it's doing this, and what can I do to fix it?
CD
Pullet_Surprise
York's
I think this clicking is down to a component on the board rather than a sound issue. I get the same, intermittently, and I've heard of others with the same problem. I’m not sure if there is a fix as such?
Which outputs from the rear are you using for audio reproduction ?
Do you have the volume of the receiver turned up fully
Which firmware version ?
