dannylaaa
- 1m Orbital, TM2600 Super, AZBox Premium.
- Liverpool
Hi all, couldn't find a place to make an introduction so decided I'd just wade in with my questions and hope someone who has been in my position can give some advice.
I currently have nothing in terms of equipment apart from a TV and a couch. My main intention is to get whatever option will allow me to watch as much footy as I can.
After looking around various forums I'm leaning towards a motorised system and I'd like the best receiver I can manage (future proof - 2 years without replacing), ideally for under £500.
The back of my house is predominantly west facing but with the shape of the building there is a south-facing wall which I think would be a reasonably inconspicuous and sheltered place to fit the dish.
Due to me living in a terraced house though my neighbour has a similar wall protuding from their house - only around 2.5m - 3m away. I'm not confident with that proximity that the distance/line of sight needed to view satellites would be sufficient ... I have no clue whatsoever about angles/elevation but looking at the row of terraces running away from the back of my property they have little Sky dishes apparently directed into the upstairs windows of the houses across from them - probably 10m away - they don't appear to be clearing the rooftops in any case.
Can anyone advise if it would be possible to mount a dish (as high up the wall as I can manage) or is this a non-starter?
Failing that I have a small chimney breast at the back which is set back another 2.5m from the neighbours which wouldn't be as 'cramped', although on the left it would be turning into the slope of my roof if motorised.
I'll be gutted if it's a no on both counts - my next door neighbour has a Sky dish bolted to the front of their house. I don't really want a dish slapped on the front of my house (the missus wouldn't be impressed) and from what I've read I'd need to go above 80cm to make it worth my time.
Sorry the question is a little vague - if you need any further information then please ask and I'll try to provide it.
Thanks, Dan
Thanks, Dan
