satellite cables throught the wall
zahir18
sky hd
london
Hi there,
I am in the process of installing my satellite dish with an octo lnb. I will be drilling a hole in the wall to pass the 8 cables through and I wanted some advise on how to fill that hole afterwards as it will be fairly big. I have seen online selling tidy hole/ grommet but its only for 2 cables.
I would really appreciate any advise and support
Drill 40mm hole and put 40mm plastic pipe inside. Then all 8 (in the future maybe more) cables lead through this pipe. After all cables are in, seal both ends with foam (easy to remove if needed)
