busman12
- Mar 10, 2007
- Age
- 52
- Sky+
- UK
I have set-up my own sat system with a dish and a Topfield TF4000pvr receiver so i can get just the free sat channels.
I have been told that if i purchase a `freesat` card from sky so i can watch the encrypted free channels, the card would only work for awhile then it would have to be inserted in an actual sky box for updates so it can continue to work.
1. Unfortunately i do not have a sky box.
2. Someone else has mentioned that if you have ccCam, the cards will work ok without having to insert into a sky box.
Whats a ccCam ? and how do i know if my receiver has it ?
Here is exactly what is says in the instruction manual :
1.3 What is common interface?
Some broadcasts are scrambled so that only paid
subscribers can enjoy them. Scrambled services
can only be viewed with a Conditional Access
Module (CAM) and a subscription card belonging
with the scrambling system.
Common Interface (CI) is the slot on a digitial
receiver into which a conditional access module
may be insterted. The front of the digital receiver
has two common interfaces
I am getting more confused than ever.
Plus are there any other cards i can use in this receiver to get more channels ?
Thanks.
Thanks.
