I haven't tested a signal before and after the connection. However, there are some other parameters. If the connectors are not fitted to the cable properly then the signal loses its strength because of bad work.4dbennett said:Barrel connectors deplete the signal strength by 10%, i have two feeds off a four feed lnb and they are of the same length cable except one has a join with a barrel connector and the signal strength is exactly 10% lower, the signal quality is unaffected.
regards dave
Robbo71 said:So that's worse case about 3dBs loss then, which means you lose approx 30% of the signal voltage you had on the input to the barrel.
Equal to about 10m of satellite cable.
4dbennett said:NICE %,s Robbo:-Nooo:-Nooo
dave
