7mdish
- CM 2.4m motorised offset dish, Viking Ku-band 2-ports motorised feed, 2 SMW LNBs, RC2000A, Dreambox DM920.
- Milan, Italy
Reading discussions here about satellite DAB+ radios, I would like to try something, but I have no linux skill so I'm looking for something simpler and easier to use.
Browsing the web I found this:
www.2wcom.com
It seems a professional device, but I do not understand what exactly it does. Is it only a converter to supply terrestrial DAB+ transmitters? Or can be used to play the satellite DAB+ streams in such way?
Also, what about very low symbol rate, non-DAB radios? Which receivers are used by the broadcasters? It seems that 2wcom builds more audio receivers with analog outs too, but they get symbol rate values not lower than 1000, so I think they are not compatible with signals having SR of 100, 200 or similar.
Any informations about this topic is very appreciated. Thanks.
High-density EDI/ETI Converter DAB-4c - 2wcom
An ASI interface (in/out) and an optional satellite tuner enable very cost efficiently to operate DAB in already existing distribution systems, or to optimize coverage and distribute programs to regions that are still lacking broadband IP. Moreover, the solution accords to specifications like...
