boothuk
- Don't have any yet! Still researching!
- North West England
Good afternoon,
Thank you to all the people who contributed to my previous topic. The information has been assimilated and I am keener than ever to set-up a motorised satellite dish! On the advice of Wod, I am posting this topic which will hopefully establish the feasibility of a dish being put on the house. Any help is again, very much appreciated.
I have tried to get some satellite images of my location in order to give you a viewing of my surrounding. The images below all have the satellite selected as 28.2 E.
A bit of background; unfortunately, the house is not mine and therefore, I am not at liberty to plonk a dish anywhichway. Furthermore, the owner isn't convinced on me installing a dish at all.
Considerations for aesthetics are therefore vital (Not for me, I think a whopping dish is a beautifu site to beholdl!) and therefore will be the deciding factor in whether the project is greenlighted or not.
Sat1.jpg shows a general overview of the area and my initial location for the dish.
Sat2.jpg is a zoomed in view of the house with the current location of our SkyHD setup.
Sat3.jpg is the same as Sat2 but with red lines indicating limitations and the green lines obviously indicating viable locations. The blue circle is my initial opinion of where the dish should be located and ideally on that side.
Some criteria are as follows:
- Minimum visibility of the dish (even though a Penta 85 would look the bees knees!)
- Minimum visibility of dish 'popping up' over the roof, should it be mounted at my suggested point.
- Satellites I require are from around 30E through to 30W. I have no inclination to look beyond these at this point.
The questions arising are things like, can I feasible mount a dish as high or perhaps slightly higher than the roofs highest point?
Can I mount lower? I.e. with the dishes and and a slight elevation allow me to conceal it behind the highest point of the roof and thus leave no exposure from front view.
A bit more information on location:
Latitude: 53.5638°
Longitude: -2.5013°
*OR*
Latitude = 53.5641, Longitude = -2.5016
Lat = 53 degrees, 33.8 minutes North
Long = 2 degrees, 30.1 minutes West
Thank you in advance for reading the above. O-zzzU-zzz
If you need any further information, I am happy to disclose. I may perhaps get some photographs of the house proper if they'll help, when i'm home from work tonight. Will also calculate the roof pitch which will most likely be the crunch figure in all this.
Ta!
Latitude: 53.5638°
Longitude: -2.5013°
*OR*
Ta!
