Satellite Dish non-penetrating roof mount
Satcom1
1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver.
Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band.
Chicago
Easy to make roof mount. 1.2 meter dish. :-thumbup
hello from italy
this looks good.
as long as the wood does not get to old and split.
you should be good to go for many years to come
heavy wind could cause the system to get out of alignment.
what are you receiving with this in the states?
id this ku or c band???
keep us informed
ralph:-thumbup
brilliant and many thanks :-thumbup
though some on here would insist that you are missing a few car tyres too to hold it down :-HoHo
It looks good, but works bad :)
I had experience of 1.5m dish lifted and turned over about 150kg concrete block...
