Sbs6
Bempel
Topfield TF 4000 PVR
Dragon Modul rev 4.1
Predator 3.20
Luxembourg
Hello,
is it possible to get the dutch SBS6 clear with the Dragon Module 4.1 and the firmware 3.20?? Do I have to use another smartcard.
Same question with the Matrix revolutions/reloaded?
Thanks for your answers!
Nope - Dutch channels are now secure.
Bempel
Predator 3.20
Luxembourg
Ok, Thanks.
That's what I thought.
TVDX
bitent.cjb.net
Does anyone know any official suppliers of the one off fee Canal Digitaal cards?.
Also, does it work in Dragon 4.01?.
Does it require OTA updates?.
cjgall
Topfield 4000PVR with Aston 1.07 CAM, (canaldigitaal), dragoncam,
Sky digibox,
Bush HD Freesat,
Visiosat trisat looking at Astra1, Astra2 and Hotbird.
Netherlands & Central Brittany
IF you are in the Netherlands then you can get a card from any satellite dealer.
Canal digitaal cards do work with the dragon 4.01 and yes, they need monthly OTA updates. If you miss an update you can have the pulse retransmitted through the canal digitaal website.
moordown66
Visit site
Through the website? Could you explain how please?
cjgall
Sky digibox,
Bush HD Freesat,
Go to the canal digitaal website and click on the 'service/activatie smartcard' menu.
You will get three choices:
Of course you can just click one of the choices above :)
The first one is to activate a new card, the second choice is to reactivate the card, the third one is, well how old are you?
If you choose reactive click on the card that looks like to one you are reactivating, type in the card number (Kaartnummer), type in the red security code in the red box and click on the her-activeren button. Make sure that your card is inserted correctly into your receiver/cam and wait. It usually takes just a few minutes to come through.
Its also possible to reactivate using a mobile phone by send the smart card number to 06-44300300 (or +31 6 44300300) but I don't know if this will work for none Dutch mobile phone.
TVDX
bitent.cjb.net
Will the card receive the monthly update with Dragon Cam 4.01?.
Or must you have a Canal Digitaal Cam?.
cjgall
Sky digibox,
Bush HD Freesat,
I use an Astroncrypt cam myself but I read that the dragon will update the card without problems. I can try an update on my dragon if you want but I will not be able to give you an answer for at least a month as I received the card update last weekend.
cjgall
Sky digibox,
Bush HD Freesat,
I will try to get the next update using the dragon, this will be the weekend around the 1st of October.
cjgall
Sky digibox,
Bush HD Freesat,
TVDX said:
I would be interested to see your results CJ.
I received the lastest uppdate this morning from canaldigitaal on my Topfield 4000PVR using a dragoncam 4.01 and preditor 3.21. As with all cams this is not a guarentee that the dragoncam will update canaldigitaal cards on any receiver but it should work on most.
