Service Scan Problem
btd
Dreambox DM800 HD PVR
Motorized Dish
East London
Hi, can anybody assist please. I have a Dreambox 800 HD PVR and a motorised dish.
I have managed to access the Eutelsat W2 (16.0E) and the Astra 19E) sats. Are these the most popular sats for a complete beginner?
I have attempted to access the Thor satellite but it seems to lock up the system at 55% always around the French channels.Is there a fix for this anomaly.
Welcome to the forum Bob.
You'll get the most out of a motorised system with full access across the arc, typically 42e to 30w. The two satellites mentioned are a good starting point. Regarding accessing Thor 0.8W, possibly a set up issue. More info required, are you using DISEqC 1.2 or usals?
Thanks for the reply. I am spending more time on this machine than I care to mention.
All we want to do was watch BBC and ITV and possibly a few film channels.
My son set this up before he left for Romania. IT was all working perfectly until I returned from the USA. The dish worked itself loose in the wind and I had an installer refix. He repositioned and thats where the problems seemed to begin .
On the set up side I have the following
Config Mode Advanced
Sat 01=19.2EASTRA
LNB LNB1
Priority Auto
LOF Universal LNB
Voltage mode Polarization
Inc Voltage no
Tone Mode Band
DiscEqC 1.2
Toneburst None
Commited DiSEqc command None
Fast DiSEqC no
Seq Rep no
Com Order committed Toneburst
Un com DiSEqC command None
DisCEqC repeats None
Long 000.023 East
Lat 051.575 North
Useusals for this sat yes
Press ok & return till I get to Automatic scan. Asks Clear b4 scan Yes
Scan Tuner A (DVB-S2) Press OK
Displays 04=10.0E EUTELSATW2A DVB-S QPSK 10960H/666/7/8 Scan in progress-0%done! 0services found.
And thats it.
Well you are scanning the wrong Astra, you need Astra 2, freesat is on 28.2/5 East not 19.2 East, secondly when you got the guy back to re-align the dish did you specify the correct satellite?
As you may have gathered I am not a techno person. In answer to your question.
When the man came back to realign the dish he told me It is aligned to 1 deg West. He could have told me it was now aligned to the Labour party or the BNP and it would have meant the same.
I have since been playing with the dream box and have managed to get ITV and BBC channels. That will have to do.
I suppose its the time of year and maybe the weather, trying to get anybody out is nigh on impossible.
Thanks for the responses.
No problem with that we have all had to learn at one time or another
btd said:
In answer to your question, When the man came back to realign the dish he told me It is aligned to 1 deg West.
I suspect he was meaning he had used 1 West as your due south satellite, this is normal practice when setting up a motorised system
Yes I agree, they should all be tarred and feathered, but we are not allowed to discuss politics
Well good for you that is a result then
CAN ANYBODY HELP???
i have a dm800 clone box with Apls BSBE2 (DVB-S2), running on GEMINI 4.4 bootloader 75#. i get all s*y channels including movies and sport and BBC HD and Luxe HD also Rush HD. but no s*y hd channels or any other
can anybody help i even got another ALPS BSBE-2 tuner and still the same problem should i change the image or is there any settings i just don't know it is like i have now 2 dm500 boxes please i need help IF ANY BODY HAS A STEP BY STEP I WOULD APPRISIATE sorry for spelling
