Setting up a BT SVS 200 CRYPT DECODER
georger
dell 3000
kent
Require an instruction book for
BT SVS 200 CRYPT DECODER.
any ideas where I can obtain one
thanks
What do you need to know?
georger
dell 3000
kent
Ihave not a clue how to connect up and to what,
to digi box or the telly or both, came with just
power lead and controller.thanks
Try this for starters:
_http://www.selkirkshire.demon.co.uk/analoguesat/gettingstarted.html
which is part of my massive AnalogueSat site.
Ive changed the title of the thread to make it more accessible.
I used to have one of these, but did not retain the instruction book, the tuning frequencies are not the transmitted frequencies, but the IF (converted frequencies), otherwise the setup is pretty straightforward.
What is your dish pointing at?
georger
dell 3000
kent
disk ex sky :
If it is ex Sky digital, then you won't find anything in analogue, you will have to move it around to the west by a few degrees.
