setting up my first motorised system - equipment check?
gazza90210
not yet
North London
hi all - this is my list of equipment:
RECEIVER:
TM5400+
DISH+MOTOR+LNB:
-Triax TD88 90cm
-Technomate 2200 diseqc1.2 motor
-0.2dB Titanium LNB.
MOUNT:
Heavy duty 50mm dia. pole 1m high ground stand
CABLE:
WF100/CT100
is there anything else i need? and is so, where is the best place to get them? thx so much
That looks like it should do the trick, what type of ground mount is it? It is absolutely essential to get the pole perfectly plumb. :)
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Looks like you have everything apart from F-connectors, self-amalgamating tape or rubber boots, cable clips, cable ties. I think you may be able to get all these items in your local DIY store for example.
Robbo:)
