setting up raven 60cm dish with Technomate TM-2200 Super DiSEqC Motor
townni
humax foxsat
Gloucestershire uk
hello i need some help.
Im instaling a 60cm raven zone 2 mini dish with a Technomate TM-2200 Super DiSEqC Motor but i have run into a problem.
When trying to instal the motor the diameter of the motor arm is 2 inches and just fits onto the bracket of the dish but it does not leave enough space to fit a bolt to secure the dish to the motor arm.
Does anyone have any ideas on how i can secure the arm to the dish before i rip all my hair out
thanks in advance.
I used two thin 4" U bolts and crossed them over when I did mine years ago, worked OK.
any idea where i can get some from as i have looked in homebase and bandq and no luck
