Dogz11 said:Needs tidying up obviously and i'll do that once finished.
Dogz11 said:is there a quick check to see if its patched ?
:-worship
exactly the same as me. Got an installer in for £20 and he moved the dish to its "proper" position. I had tried for two hours but Thor was not where my compass said that it should be. Everything ok now.Dogz11 said:Pole plumb in both directions, triple checked
Lattitude and longitude set in technomate 5400 ci reciever and near as dammit corresponds with London (i'm in woking and used info from dishpointer.com) so they're in the right way round.
Due south located with a rangefinder compass
Told reciever to go to Thor, which results in a very small burst of movement.
then...
Signal Level... 89%
Quality .... 22%
No picture.... get the bbc world channell up (no signal)... sit there and fine tune / move the dish east and west for ages in either direction no picture or signal quality still. Tried moving the dish up and down same, tried moving the motor around the pole same.
Strange thing is when initially setting it up we did at one point get a channel briefly, but nothing since .....'O'-red
help please
Dogz11 said:once on 8 degrees i'm moving it really slowly about the pole but bugger all till astra kicks in
any explanations please
Dogz11 said:Hi Peeps ...missus has cleared off ;)
I'm desperately trying to set this up properly....resetting the motor to the reference point. Then no matter how carefully i move it in either direction, using a meter i cant locate thor, i can locate 8 degrees / nilesat, but the damn thing will not locate thor, its either 8 degrees or astra )(-red
You should be able to just flex it to find it, it is only slightly higherDogz11 said:INcrease or decrease the dish angle ? i assume increase ?
