sharing help required
abdul.jabbar
tecknomate to next patched
uk
Here goes
Hardware setup: I have an eagle box(dm500 clone) with pli jade image connected to internet via router. All downloads work. The ip adress is set to 192.168.1.10. This box has the inadyn plugin all set via yellow button.
user: here i added my username when registering the no.ip site
pass: Password entered
alias:cardshareone.no-ip.biz .......I HOPE THIS IS OK.....
Domain: The drop down menu gave me 2 options. Ichose no-ip.com
update i chose 30 mins
Saved and exited
My config file in var/etc via ftp is:
#This config was created using the Dreambox Config Creator.
#Designed & Written by B16MCC
SERVER LISTEN PORT : 12000
SMARTCARD CLOCK FREQUENCY : /dev/sci0 3430000
F:user pass 1 1 1 { 0:0:1 }
INFO LISTEN PORT : 16000
HTML INFO LISTEN PORT : 16001
ZAP OSD TIME : 0
OSD USERNAME : root
OSD PASSWORD : dreambox
SHOW TIMING : yes
MINI OSD : yes
DEBUG : no
DISABLE EMM : no
EXTRA EMM LEVEL : yes
SOFTKEY FILE : /var/keys/SoftCam.Key
AUTOROLL FILE : /var/keys/AutoRoll.Key
STATIC CW FILE : /var/keys/constant.cw
CAID IGNORE FILE : /var/keys/CCcam.ignore
LOG WARNINGS : /tmp/warnings.txt
As you can see creatd by B16MCC program....
I have a second box in a different room also connected to the router. It is a dm500 clone.This can also download via internet and has pli jade image. The ip is set to 192.168.1.20
The config file for the looks like this, again ftp'ed to var/etc using dreambox control centre
c:cardshareone.no-ip.biz 12000 user pass 1 1 1 { 0:0:1 }
ZAP OSD TIME : 0
OSD USERNAME : root
SHOW TIMING : yes
MINI OSD : yes
DEBUG : no
DISABLE EMM : no
Both boxes work when a cline is added, therefore they can connect to the outside world to someone elses server. I have tried a free server which lasted a couple of hours.
I have a gold card for the sct channels at 13 degrees east. The card works on both boxes. But when insert card in the server box (192.168.10 the eagle) It does not work in the client.
Both boxes have cccam info plugin which shows connected sever from client box but no picture
On my pc with the no ip account there is a program called no-ip duc v2.2.1 running which shows my host cardshareone.no-ip.biz and at the bottom of the window shows using ip address 81.108.xx.x dyn has been successfully updated
I have also gone to my router ( vigor 2910) to nat/open ports. Here it shows 2 wan ports, both with local ip as 192.168.1.13 (My computers ip address). Clicking on wan1 and than wan 2 takes you to another menu where i ticked open port for bot udp and tcp and opend ports 80(this was allready there as opened), 12000,21 and 16001 savced and exited.
I asume i put card in server box(192.168.1.10) make sure its working go to clinet box and view.
I cannot get it to work despite reading all i can find. Prbably something minor now but cannot figure it out so help required Thanks for taking the time to read
