SID not found in PAT
haji24
technomate
newport
Hi somehow i have lost all sports interactive on my DM8000 just wonder if i need to change some setting.
Thanks haji
Lost? In what way.
Ive found the BBCi channels tend to disappear out of the main 28E channel list on my 7020. The fix is easy - put them back into the tv channel list using Dreamboxedit, THEN put them in a favourites folder. Even when the channels disappear off the 28E list they are still available from the fav list.
I think the reason they disappear is they are actually flagged as data channels not tv channels. You can change this using DBE but the tv/data flag on the channels gets reset for no apparent reason at erratic intervals.
Analoguesat said:
Delete them and rescan
i did delete them after rescan nothing come up all disappeared and couldnt find any frequency to search for them
