bcfctrev
- Aug 9, 2010
- Age
- 51
Dreambox DM800 HD
80cm motorised dish
- Birmingham, UK
hopefully this is in the correct area of the forum (I apologise in advance if it isn't)
I have a DM800HD PVR clone
Nabilosat BlackHole
CCCam 2.1.4
80cm motorised dish
15metre cable run
when I change channels, my SNR (whatever that means) fluctuates between 70 - 95%, and on certain Sly channels, the screen will pixelate for a couple of seconds, then go back to normal viewing for about 3 minutes, then ixelates for a couple of seconds again. Would / could adding a sloping 13-18db inline amp cure this problem?
Thanks in advance for any help
bcfctrev
Nabilosat BlackHole
CCCam 2.1.4
80cm motorised dish
15metre cable run
bcfctrev
