signal quality
Likes
DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux
Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr
that would be telling
#1
)(-red )(-red )(-red )(-red :-bash i have set up my technimates 7755 2va 2ci stab 120 motor 85 cm clear dish and every think went well tile i checked the signal quality.signal reads 88 quality only 10 ive changed the longitude by 000.1 and no luck poles plum motor south checked with digi compass dish facing thor 72 on the digi sat meter still no luck wot else is there to check i need help thank you:mad: :( 'O'-red :(
Lancelot
Likes
SS1.
36v H to H 62E - 61.5W
South central
#2
What are your channel settings on the box, Freq / Pol / S/R ??
L.
Likes
#3
its a motorised dish and i just scanned 19e signal quality is 90 signal 80 perfect channel scan 650 stations.but i need thor to set it right how do i do it without losing the signal quality
Lancelot
Likes
SS1.
South central
#4
Try this one - it's nice and strong :)
L.
Likes
#5
i think i need to start again but the signal on the sat meter was strong but why is it no good on the quality
Lancelot
Likes
SS1.
South central
#6
Possible wrong Symbol rate setting in your box ???
L.
Likes
#7
L.
symbol rate is 24500
Likes
Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
Midlands
#8
Just for info, signal "quality" is (usually!) derived from the Viterbi inner convolution stage, basically, it shows how hard the error correction is working to "clean up" a corrupt signal.
So, if quality is low, that means the received signal's very corrupt (indepedently of strength, high strength should also mean good quality, but not necessarily!), so received bit errors are high, and the viterbi decoding is working unusally hard!.
It shouldn't have anything to do with the actual symbol rate, since the sig/noise ratio of a satellite channel is fixed by transponder power, and modulation method (always QPSK).
Usually, this would mean an interferring signal, maybe the lnb polarisation's off, or just possibly rf interfernce from another source?
Lancelot
Likes
SS1.
South central
#9
Are you using the settings in the attachment above ??
L.
Lancelot
Likes
SS1.
South central
#10
I find it does :)
L.
Likes
#11
it looks set to thor but the signal quality is still10 this is the best singal on the digi sat meter at about the thor area on the sat finder still on joy tp's whats that all about very very new to this
Lancelot
Likes
SS1.
South central
#12
The reason this S/R thing got started was that I was trying to ascertain that you were actually on 1W and not just thinking that you were.
Try a full scan of Thor with your box, are you getting a signal on all or most of the transponders listed for 1W on your reciever or just some of them ??
L. :)
Likes
Midlands
#13
Lancelot said:
I find it does :)
L.
In which case, Llew, Technomate's "signal quality" is somewhat different from the usual meaning, common to other DTT and sat box makers ....(added) Sorry, I should have said "Lancelot" not "Llew", must try reading what's in front of me, huh?!
Lancelot
Likes
SS1.
South central
#14
I was going to add that it might be an SS1 thing here, but thats what I find.
And I'm Lancelot :D
Llew is the good looking one ;)
L.
Likes
#15
i think i may of sorted it out will see tomorrow to dark now.the sta compass i have got as been giving me wrong read outs it was showing thor but it was astra 19e just moved it to the right and iam on hotbird now signal quality 60 .all this time i have been a few hundred miles out tomorrow if i move it to the right a bit more i think (hope) i will come across thor thank you let you know tomorrow
Lancelot
Likes
SS1.
South central
#16
Good.
That'll be why then. The S/R was wrong for the signal you were recieving because you were pointing at the wrong sat.
Seen it before. You'll be fine now :-righton
L.
Likes
1,279
#17
You will also need to lift the elevation of the dish to receive Thor.
Likes
#18
i just cannot understand the sat/compass giving the wrong reading i brought it to help it has made it worst.so if i set the motor and dish to thor will that be ok or will i have to set the motor south i have not got a compass so i will just have to guess a couple of taps with the hammer left should be fine.:rolleyes:
