Sky + Box for receiving FTA channels?
alexandjen
Ross 65cm dish and freesat receiver (used in the weekend pikey wagon)- pc is self built (and old) 2gb ram, 3 x 80gb hard drives, 2gb Intel processer, dvd and cd burners, sony 17" monitor.
Sittingbourne, Kent, UK
Newbie here so apologies if this has been covered before.
I've got my eye on a second hand Sky+ box and am wondering if it is possible to receive the Astra sat channels without a viewing card? :confused
TIA, John
Yes - although remember you wont have access to the recording facility unless you get a fsfs card and pay atenner a month fee to sky.
If you want to record get a Freesat PVR.
alexandjen
Many thanks for the swift reply - glad I asked, it doesn't seem worth getting a plus box then if it only records with a card.
So a standard Sky box will receive all FTA channels?
Yes of course it will :D
Fiver / +1 Five USA & Sky 3 are not fta and require a fsfs card.
There are a number of differences between the channels on Freeview and the free channels on Freesat so dont expect Dave and half a dozen others.
Which channels are vitally important to you?
satelliteman
As does Channel4+1. Another one that requires a fsfs card.
alexandjen
None are vital, so it sounds as though I could manage, thanks again:-thumb1
Does it?? C4 +1 is fta.
satelliteman
Remove fsfs card, reboot and check EPG.
Ok it might not be mapped onto the epg without a card for some insane reason.....
satelliteman
Yes to rephrase that, fsfs card or above for Ch4+1 to be listed on sky EPG, other wise it's add channels function. Certainly an interesting one.
