don'tknowdon'taskme
Part Timer
- DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux
Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr
- that would be telling
HI NEW MEMBER JUST FITTED SKY+ BOX GOT OFF EBAY AMSTRAD DRX180 PUT NEW QAUD LNB IN TWO CABLES SEEMS TO WORK FINE BUT GET NO SIGNAL ON THE 2ND LINE WHEN I GO TO SIGNAL TEST. I HAVE UPGRADED TO SKY+ (sky was not very happy about the phone line not being connected) SEEMS TO RECORD NOT ON THE TIMER BUT THATS FOR LATER TO SORT OUT OR IS THIS BECAUSE OF THE 2ND SIGNAL PROBLEM.IF YOU CAN MAKE HEADS OR TAILS OF THIS HELP THANK YOU.
