Sky remotes - reprogram standard to operate Sky+ or HD and vice versa
As the title says how to reprogram Sky remotes (and reset them to factory defaults which can cure non operating remotes. All remotes have at least 8 different modes (HD have 12). Obviously standard remotes do not have the Sky+ function buttons but recordings can be played from the planner by highlighting and pressing "Select" twice and stopped by pressing "Backup" - no pause, FF, Rewind or Record buttons (but recordings can be set from pressing "record" on the box.
For most remotes Version 4 and later (white label inside battery cover)
1 Press "TV"
2 Press and hold "Select" and "Yellow" together until red led in remote end flashes twice (On HD remotes "Select" and "i" together) - if it doesn't flash twice then remote cannot be reprogrammed (clone or too old)
3 Press "0" to operate standard box, "1" for Sky+ and on HD remotes "2" for HD - remotes in Sky+ mode will normally control HD boxes as well
4 Press "Select" - red led should flash twice
5 Press "Sky" and away you go
