my friend is thinking about buying a second hand sky plus box to watch the free channels.
he was also talking about putting a bigger hard drive in it.
ive got sky plus on a contract and ive heard you cant use sky plus without a contract. is this true?
thats what i thought, he'll be dissappointed.
how does the box not allow you to use the hard drive even if youve paid for the box?
or what happens if youve had a contract and decided not to renew it?
Dont knock VHS - I dug out some old tapes the best part of 20 years old a few weeks ago, and they play just fine. I bet you will struggle to find a player for your BluRay DVD's 20 years from now things change so fast
ive been talking this over with my mate.
the thing is i quite fancy fitting a bigger hd, ive only got 40gb.
can anyone point me in the right direction ?
can you recommend a good site to but from?
is it a standard ide hd or are they formatted specially?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
