sky remote code=help please :-)
petro118
Can't get sky remote to work on my tv
have followed all instructions and tried all codes in sky booklet and online???:confused
tv model is matsui 25m1 mk 111
any help would be kindly appreciated
cheers, Pete
Don't think that there is anything to suggest Pete, if you've tried them all, then there may not be one for the TV, or your remote is too old and doesn't carry the later codes.
petro118
cheers mate
i'll just sulk then :( lol
with mi two remotes
bugger
thanks again for your prompt reply i did suspect this may be the case
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
This might work Pete
1. Press the TV button on the Sky remote
2. Hold down Select and the Red buttons together for approximately two seconds, until the Red LED on the Sky remote blinks twice.
3. Key in 990 on the remote.
4. Key in 1 on the numeric keypad and count the number of times the Red LED blinks. The number of blinks will indicate the first digit of the code
Note that a 0 is represented by no blinks where you press the key.
5. Input 2 on the numeric keypad and count the blinks to identify the second digit of the code.
6. Input 3 on the numeric keypad and count the blinks to identify the third digit of the code.
Even if it doesn't it will be fun. :)
cheers, Pete
the code is 0263 hope it helps:cool::cool::cool:
He is probably sorted by now - look at the original post date - almost 8 years ago :D
04-08-2004
Thread closed :)
