Sky+ remote for Sky HD box?
redout
1M Dish with Motek 2100,
DM 500 & DM 800HD, Vu+ Duo,
Digital+, Sky+, TDT, Saorview
Dublin
Can a regular Sky+ remote fully control a Sky HD box?
Yes it can, you just need to enter the correct mode on the remote.
From memory, press the TV button, then press and hold Select and i until the LED blinks twice, then press 2, then select.
Aye, switched out the old Sky+ and put in the Sky+HD and it is responding fine to the old remote.
Thanks.
