Yeah, just replace the newcs xml file on your box with the one you download. You dont need to replace your cccam cfg file if you already have your own one configured. Just copy the first line of the one you download "the N line" and put it into your own cccamcfg file.dominus said:do we have to confi anything on the n line of cccam? I never used newcs do I just copy the file (over right? ) this that it?
many thanx
tomthebomb1968 said:Yeah, just replace the newcs xml file on your box with the one you download. You dont need to replace your cccam cfg file if you already have your own one configured. Just copy the first line of the one you download "the N line" and put it into your own cccamcfg file.
You need to use NewCS 1.60 or newer. Don't use older versions of NewCS. They can fry the card.
Put the newcs.xml in /etc/tuxbox/config/ and the CCcam.cfg in /etc/.
The version of CCcam is not important, but keep it newer than 1.71, if You want to use it for cardsharing.
Good luck![]()
Sorry m8, I dont know, hopefully someone reading this who is more experienced than me can give you some advice.sblinx said:thanks man this is very very good news
do you by any chance know if an nds3 sky it card works as well?
do you think i might need to lower the speed of the newsc file you posted from 450 to 357?
tomthebomb1968 said:Sorry m8, I dont know, hopefully someone reading this who is more experienced than me can give you some advice.
Good luck![]()
No m8, I just used the file as it came, It worked first time for me Just had to restat the cam.dominus said:Hi tom, not working. DO I need to change anything in the xml file? like ip or ports?
regards
tomthebomb1968 said:No m8, I just used the file as it came, It worked first time for me Just had to restat the cam.
Have you inserted the N line into the cccam.cfg file?
heracle75 said:donot try to read nds3 sky it card in internal dreambox reader, will cook you card.use external card reader, phoenix programer or simular...
card read well at newcs_1.60 answer time ~130ms 3,57mhz
B16MCC said:Guys, since posting last in this thread, I've now got the NDS card running in the DM800 in CCcam using the smargo reader. Please let me know if you'd like information on how to do it.
tomthebomb1968 said:-http://www.4shared.com/file/60970974/45476f7b/DM800_configs.html
