Sky UK card not working in DM800 Card Reader
Hi Guys,
I moved recently to Ireland (from France), and I'm thinking about subscribing to Sky.
I currently use a DM7000s, but I plan to buy a 800HD (and get the sky HD option).
But I'm not sure what kind of contract I should get with Sky...
Do I need a "second hand" contract?
Or can I get a regular contract, with a sky HD box (for 49€ in ireland, including free installation), and then, just use the card in my DM800 ?
and keep the Sky HD box, just in case?
Thank you very much for your help
Cheers
B16MCC said:
maxsuma11, are you using the new white card ? If so this doesn't work with CCcam or the Smargo. You have to use the internal reader and serve it up with NewCS. See my thread in the Dreambox General section about Testing the new white sly card. All the info you need is in there.
i change my smargo to phoenix reader i try cccam 204 it show only one caid but nothing clear
problem sorted cccam 2.0.11 to newcs 1.65 no freeze what so ever now perfect
another thing my old card still working too now i and up with 4 card
this is amazing
maxsuma11, can you expand on exactly what you've done here please.
What card are you using ?
What reader are you using ?
If smargo, what settings ?
Could we see your NewCS.xml please ?
<?xml version="1.0"?>
<newCSconfig>
<readers name="Phoenix">
<device>
<listening-ip>192.168.2.101</listening-ip>
<name>Sky</name>
<type>sci</type>
<mhz>400</mhz>
<node>/dev/sci0</node>
<parity>none</parity>
<reset>normal</reset>
<export>Yes</export>
<enabled>Yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<crypto-special>no</crypto-special>
<PTShandshake>No</PTShandshake>
<carddetect>yes</carddetect>
<newcamd_port>12000</newcamd_port>
<autosid>Yes</autosid>
<Seca-PPV>no</Seca-PPV>
<boxkey>myboxkey</boxkey>
<pincode></pincode>
<priority>round</priority>
<port>8080</port>
</device>
</readers>
<radegastserver>
<enabled>No</enabled>
<port>16000</port>
<allow>
<hostname>192.168.2.101</hostname>
</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<debug>
<password>NewCSpwd</password>
<level>normal</level>
<type>all</type>
<output>console,tcp</output>
<console_options>normal,all</console_options>
<tcp_port>1001</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>newcs</name>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<user>
<name>dummy</name>
<password>dummy</password>
<au>on</au>
<sidoverride>off</sidoverride>
<spider>No</spider>
card on dreambox 800 gemini 4.10 image cccam 2.0.11 to newcs 1.65 never freeze and realy fast i convert from camd to cccam show as a local at the moment work perfect
this is the cccam config
#### Servers ####
#### CCcamd Clients/Karsi Tarafin ######
N: 127.0.0.1 12000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
#### Config ####
# SERVER LISTEN PORT : #
# ALLOW TELNET INFO : #
ALLOW TELNETINFO: no
# ALLOW WEB INFO : #
ALLOW WEBINFO: yes
# WEBINFO USERNAME : #
WEBINFO USERNAME :
# WEBINFO PASSWORD : #
WEBINFO PASSWORD :
WEBINFO LISTEN PORT : 16001
# ZAP OSD TIME : #
ZAP OSD TIME :0
# OSD USERNAME : #
OSD USERNAME :root
# OSD PASSWORD : #
OSD PASSWORD :dreambox
#BOX KEY : /dev/usb/tts/0 19 39 90 3E #ndscard
#SERIAL READER : /dev/usb/tts/0 smartreader+
OSD PORT :90
SHOW TIMING : yes
# DEBUG : #
DEBUG : no
# NEWCAMD CONF : #
NEWCAMD CONF : yes
DISABLE EMM : no #
DISABLE EMM : no
SOFTKEY FILE : /var/keys/SoftCam.Key
AUTOROLL FILE : /var/keys/AutoRoll.Key
STATIC CW FILE : /var/keys/constant.cw
CAID PRIO FILE : /var/etc/CCcam.prio
work like that
itry my other card on cccam 1.2.1 old version it show the card i know 1.2.1 is the magic version also 204
pli flubber image dm500
ibeen testing technomate 9100 box perfect box for nds3 card 3.5 card reader
also some ibm processor has the same ipbox900 and 9000 sky card not get hot or burn on this boxses also new technomate 500 and 600 work realy good
