w4tt4n4b3
- Gibertini OP120 + Inverto Black Premium Twin @ 28.2E
- Greece
I would like to know the SkyBox operational outputs in order to check if it can be connected to the following devices and co-operate.
1. Blackmagic video recorder
(_http://www.blackmagic-design.com/uk/products/videorecorder/techspecs/)
Analog Video Input YUV Component, NTSC, PAL and S-Video.
Analog Audio Input Stereo consumer level RCA.
SD Format Support 625/25 PAL and 525/29.97 NTSC.
2. Pinnacle Video Transfer
System Requirements:
Input connectors
o Composite Video: 1xRCA (PAL-SECAM-NTSC)
o S-Video: 1xY/C (PAL-SECAM-NTSC)
o Stereo Audio: 2xRCA
o Capture format: H.264
Capture quality:
Best: 720x576 PAL/Secam 720x480 NTSC 2,5 Mbit/s 192kbit/s audio
3. Pinnacle MovieBoard Ultimate version 12 (pci card)
(_http://www.pinnaclesys.com/PublicSite/uk/Products/Consumer+Products/Home+Video/Studio+Family/Studio+MovieBoard+Ultimate+version+12.htm)
Capture Options
* Capture from DV, HDV and Digital8 camcorders or VCRs (requires a FireWire® port)
* Capture from analog camcorders, 8 mm, HI 8, VHS, SVHS, VHS-C, SVHS-C, or VCRs (NTSC/PAL/SECAM). Requires DirectShow® compatible graphic board or TV tuner board with analog (Composite or S-Video) inputs
Import Formats
* Video: AVCHD*, DV, HDV, AVI, MPEG-1, MPEG-2, DivX®*, MPEG-4*, 3GP(MPEG-4)*, WMV, Non-encrypted DVD titles*
Export Formats
DV, HDV, AVI, DivX*, RealVideo® 8, WMV, MPEG-1, MPEG-2, MPEG-4*, Flash, 3GP*, WAV, MP3* files
4. Samsung DVD R149 DVD recorder with TV tuner
(_http://uniontechpc.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=5069)
Connections
Connector Type 1 x composite video/audio input ( RCA phono x 3 ) - front 2 x SCART ( 21 PIN SCART ) - rear 1 x digital audio output (optical) ( TOS Link ) - rear 1 x digital audio output (coaxial) ( RCA phono ) - rear 1 x composite video/audio input ( RCA phono x 3 ) - rear 1 x audio line-out ( RCA phono x 2 ) - rear 1 x S-Video output ( 4 PIN mini-DIN ) - rear 1 x component video output ( RCA phono x 3 ) - rear
Reception System
PAL, SECAM-I, SECAM-D, SECAM-B, SECAM-K, SECAM-G
Does the Sky Box have an operational analogue component?
Will the Sky Box (not the PVR) be able to co-operate with any of these devices?
Which would be the best choice?
Input connectors
Capture quality:
Capture Options
Import Formats
Export Formats
Connections
Reception System
