Skystar 2 Transponder Help
djc
Likes
DM7020-S
88cm Triax Dish
1.8m Channel Master soon to be installed
Doncaster
#1
Thor 3 (0.8W) - 12246.00 H - DVB/MPEG2 - 28000 7/8 - NID: 4369 - TID: 1
Trying to get the above on my SS2. My 80cm dish is a 1W, but doing a scan on the following returns no results.
With me being a novice and all that, I could be missing something, so any help would be great.
BTW, reason I am trying to get the above is that they're showing a few channels FTA at present, according to King of Sat.
Cheers
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#3
err so a 80cm is too small ? I am in mid to north England.
Can't even get a little bit of a signal, surely I should get something ? Think I might be doing something wrong.
Lancelot
Likes
SS1.
36v H to H 62E - 61.5W
South central
#5
97cm & 0.6db and I'm getting 35% sig & 45% qual where I am on an SS1, sadly not enough to resolve a picture. :(
You should try this sat between 6 and 9 am as you will have a better chance then.
L
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#6
Do you think a 1.1m with 0.3 LNB would do it ?
This Satellite business is doing my head in, first I'm looking at receivers, now I am looking at scrapping my 80cm for a 1.1m (motorised). Don't want to go any larger than 1.1m as this thing as to be mounted on my wall.
Do you think it would be worth doing, I mean not just for the current FTA I wanted to view, but will it open up more channels for the future ?
Cheers
Hairybathplug
Likes
The main targets are 19º 13º 1º and 30º all of which you should get with 80cms, there is sometimes free footy on 5º 16º and 42º again I get them with my setup 80cms and 0.6mti blueline. She who must be obeyed said I ain't allowed a 1.2 on my wall, but it could be usefull. I guess it's down to how freindly you are with your neighbours, will they complain?
HBP
Lancelot
Likes
SS1.
South central
#8
A good installation with a 110cm (Triax seems to be the favourite in this class although is only 105cm) would probably do it, although without a 120 - 150cm antenna you will be prone to 'rain fade'.
If you seriously want the weaker transponders at this location then you must consider a 150cm ground mounted antenna to provide good all weather reception. :)
L
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#9
Forget it, I'll stick with my 80cm. Doesn't sound like its worth the hassle.
Thanks anyway.
Lancelot
Likes
SS1.
South central
#10
Y'r welcome mate. S'wy wer here. Now you know something about that thing, you can help someone else if you see the same prob again . :)
L
