- Jan 1, 2000
- Age
- 59
- 1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
- Somewhere where the Sauer is Kraut and the Wurst is Brat
spock_uk said:A question
How can I save all the Satellite settings and channels so I can just reload them on after it crashes and I have to reflash.
It not auto find the Satellites and I have to manually set them.
I have a hardisk 120 MB fitted. Can I save the setting to that as a backup? or by FTP?
spock_uk
Why do it the easy way when there is a more hard way?
Its does not compute ...
Hi Spock
It's logical mate: go to my idiot guide
http://www.satellites.co.uk/php-bin/forum/showpost.php?p=123374&postcount=4
and read all about the Dreamboxedit prog. This is what I use, and it is a great little thing. I have attached my settings, you could try it out and load it onto your dreambox next time you have put in a new image. You can also load up my settings, then compare it to what you got on your box (Go to Tools, Compare loaded services ....). It will then give you options how to sort it all out so you got the whole lot. As long as you keep a backup once in a while you'll be ok
Now I am not sure how it works with a 7000 and hard drive, as I only got a 5620 connected to a computer, there it takes something like 15 seconds.
Maybe some of the others can give you a hand with that?
TG
