Sony Sky Digital Receiver - Channel Loss
nsharma
I have a Sony VTX-S750u Sky Digital receiver which had been running OK for a few years. On channels such as Performance, SAB TV and a few others, I get a message which says that "No satellite signal is being received". The same channels are OK using another receiver which hopefully proves that the dish alignment, LNB and cables are all fine. Am I correct in thinking that the tuner in the Sony receiver is playing up and if so how can this be fixed?
Many thanks in advance,
With kind regards
Alot Off The S750u Have The Same Fault You Can Get Them Fixed But Quiet Dear As Sony Will Not Make Them Eny More . It Might Be Possible To Switch (if) Turner Inside With An Old Amstrad Drx100 But Thay Are Just As Bad
