Splitter Help Please
zebbee
Quad LNB - 2 to Sky HD+ Box (in Lounge), 1 to old Sky Box (Bedroom TV) and 1 to Grundig GUFSAT02SD box in Kitchen.
Kent
I have a Quad LNB - 2 connected to SkyHD+ in the lounge, 1 to old Sky box in bedroom and 1 to a Grundig GUFSAT02SD in the kitchen. This all works fine but...my better half uses the TV in the kitchen to catch up on her programs recorded on Sky+ (achieved via a Phillips wireless TV link transmitter which works well for us).
This ties up the TV in the lounge BUT it does have an inbuilt Freesat receiver so I thought I'd try putting a splitter in to share the signal with the kitchen - knowing we'd never be competing for the signal at the same time.
Having experienced problems with this today, i now realise its cos the TV connected to one particular output of the splitter effectively 'drives' the signal and hence that TV's receiver box has to be switched on. Furthermore, the channels available to the other TV (in my case in the lounge) are fairly restricted.
So, whilst not perfect, at least its an improvement. I guess I could temporarily swap the outputs from the splitter to give me all the channels in the lounge.
However, is it possible to buy a splitter whereby you can manually switch control between the two outputs rather than physically change them?
Suggestions for an alternative solution also welcomed!
(By the way, my good lady is not confined to the kitchen. It is her choice! I guess Sky Multiroom would be another option but I would prefer to avoid any further monthly charge - its expensive enough already).
Thanks in anticipation
Zebb
Don't bother, that can not be classed as a 'solution', using splitters is a waste of time, just simply by an octo lnb and put in the extra cable and you also have room for expansion and or extra recording possibilities.
I am sure one of our advertisers can help you out with one
http://www.satellites.co.uk/forums/635-forum-supporting-advertisers-special-offers/
Or there is always amazon
-http://www.amazon.co.uk/Sky-OCTO-LNB-8-Way/dp/B000W4EGKE
Totally agree with @Topper. The price of the octo's have come down so much, it's much easier and cost effective to go along that that route.
If you are happy with using only one of the two at a time, then the cheapest effective manual solution is an A/B Switch (Often called a Cable Isolation Switch).
I have two or three of these for helping reconfigure my systems flexibly and the bonus is that they are numpty friendly too: Got no signal? Press the button!
And they are cheap.
eg eBay Item 190351592624
What you need is a so called priority switch. These were used in the past to connect an additional Digital stb to a single coax connected to an Analogue receiver. Output A takes precedence.
I doubt this would work in this instance. If you put the priority to a $ly box it will be permanently switched that way as they always have the LNB inputs as live. Similarly, putting priority to the TV might do the same and would certainly be prioritised all the time it's switched on - which is most times surely!
Good point.
A/B Switch >>> £6 >>> Sorted!
Hi Folks. Thanks for all your comments. Much appreciated.
I'm attracted to Blind Faith's suggestion of a Smart Priority Switch. If I give priority to the Kitchen (Grundig receiver - which is rarely on) and make the Lounge TV (Freesat receiver) the slave, then this seems a perfect solution as no manual intervention at all will be required. (Paul R: This should overcome your concerns I think).
Can i just check tho, if the Kitchen feed IS in use, will I still expect to get a reduced set of channels in the Lounge via the slave feed (as ido now wiith my splitter) or will it get nothing at all with this priority approach.
or t r with Presumablyndindepe the ideal solution. perfect tosi would s arcye mBlind Faithaited
..if the Kitchen feed IS in use, will I still expect to get a reduced set of channels in the Lounge via the slave feed..
..yes you will. You can get all channels restricted to the same band (high/low, hor/ver) of the kitchen (master) receiver :)
You say the receiver is rarely on but when in standby (not off) the LNB input is still live. It won't work as you want unless you remove the mains plug from the wall socket.
Just use the A/B switch: Full set of Channels on one set or the other.
Cheap.
Simple.
Foolproof (Got no Channels? >>>> Push the button!)
