Spraying a dish - help needed
Likes
3m Motorised Dish with Manhattan Plaza ST-550
SA
#1
My 3m C-band dish has begun peeling, so i wanted to spray/paint it.
But while at it, i thought it wud do gud if i could get something that wud improve signal strength as well - so is there some magic paint i cud use to for this purpose? Of course it shudn't sacrifice protection for the dish (we have some nasty weather here).
Please advise.
Also when spraying, should i be concerned about the LNB getting covered in spray. Being a 3m dish, I'll have to do the spray job on the roof.
Oh yes, and shud i strip(if so, how?) the existing paint or just spray over it. Getting it off the mesh mite be a challenge tho.
Thanks in adavnce for any help.
2cvbloke
Bulbs need shelter too...
Likes
1,712
Near Pontop Pike, Co. Durham
#2
There's not any "magic" paint as far as I know, I resprayed my Ku dish with standard Matt black car paint, don't use metallic paint as this can mess up your dish's performance, and wear a safety harness if your doing it on your roof!!!
Rob
Likes
Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
#3
As 2cvbloke says no magic paint, but no need to strip the paint work just rub the existing paintwork down (use a sander if possible), and either remove or cover the LNB.
Use a good quality air drying paint and make sure it's a MATT finish NOT gloss as you might end up "cooking" your LNB. :-Nooo
2cvbloke
Likes
1,712
#4
Just watch the Super Solar Weapon episode of Mythbusters with their C-Band mirror dish, setting fire to an oily rag or whatever it was... ;)
