ss2 problems think its a codec
pothead13
Likes
Technomate 1500ci + 1000d super +
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
pc + laptop on network
uk
#1
hi when i watch some channels on ss2 card i find the video skips everynow and then and realy anoying is ther a codec im missing or does an one know what problem is i got everything else working ok
Lancelot
Likes
SS1.
36v H to H 62E - 61.5W
South central
#2
Could be your PC as SS2s are hungry beasties.
What spec is it ??
L.
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#3
p4 3.2ghz 1gb ram 256 nvida graphics win xp
Lancelot
Likes
SS1.
South central
#4
That should be plenty fast enough.
Which viewer are you using and which drivers ?
L.
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#5
prog dvd TechnisatDrivers4.3.0 it dont do it on all channels but on a few like video-n - dmand and mtv and tps foot the pcture flickers for couple seconds every now and then never done it on my reciver box
Lancelot
Likes
SS1.
South central
#6
Tricky one that.
You could try the 2.17g drivers from Technotrend.de.
Used to get the same effect with the SS1 when it lived with an AMD K6 3 400 many moons ago.
L.
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#7
no that never worked is ther a way to turn timshifter of as they maybe causing it
Lancelot
Likes
SS1.
South central
#8
Having an SS1, I can't 'try out for real' your problem but I didn't think the SS2
supported timeshift ?.
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#9
4:
click to enlarge
Lancelot
Likes
SS1.
South central
#10
So disabling does what ??L.
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#11
Lancelot
Likes
SS1.
South central
#12
Try setting the buffer and cache sizes to 0
L.
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#13
dont let you do that says buffer must be > 2mb
Lancelot
Likes
SS1.
South central
#14
So still the same with min buffer size and all other programs (outlook. IE6, all other stuff ) closed down then. Not even a small difference ?
L.
nacturnal
Likes
When we are using progdvb to watch fta channels there shoudn't be any problem. we may face problems when we want to view scrambled channels (with yankse etc).
Use dvbviewer software supplied with ss2 or u may use dvbdream to find out
the problem. Usually problem persist with software installations . uninstalling and reinsatlling the software and drivers may rectify ur problem.
