still need help
johnbruce
hello to the group
i have myself a infinity usb pheonix
and i wanted to know how to programme my matrix reloaded.it has nothing on it (except ucas3.0)and i need to know how to programme files on to it.exactly how do i do it ?? also what files do i need to do this. any help
im still trying to understand how it works so as you can probably tell im new at this. please help me im stuck otherwise
All you should need is a couple of fun6 cards and the relevant loader and MR 1.08 files, you should be able to get them at www.fookfiles.com
i dont understand rolfw
relevant loader ?? like chipcat
is there not a certain way you are suppost to load the files in ??
just treat me like a real dummy cause thats what im like when it comes to this
No, use the Infinity software to program the funcards, but there are two files which go on each card, the loader and the two parts of the MR file, the loader goes on both and each part of the MR on each card.
You then put the first card in the MR, after starting up on an unencrypted channel and go into the loader menu.
There should be some instructions in the FAQ and Howto section
