superjack actuator 36 inch problem
bakheet
fr1.25
sa
hi
i opened the actuator from inside and there are different pulleys with different size having white colour ,I don`t know how to install them ,does any body have a diagram for that?
thanks in advance.
Archived-1
Persona non grata
uk
hi
thanks in advance.
Can you post some pictures please bakheet.
bakheet
fr1.25
sa
bakheet
fr1.25
sa
cannot be loaded
Archived-1
Persona non grata
uk
We cant help you without looking as I said the other night, you need to help us to help you, you might need to resize the picture open the picture in paint and resize it :)
bakheet
fr1.25
sa
the picture is up
bakheet
fr1.25
sa
here is another picture
many thanks
Archived-1
Persona non grata
uk
Are you sure these aren't spares ? strange did you buy this new ?.
bakheet
fr1.25
sa
this is the actuator suprjack 36 inch from inside ,i bought it from satellite superstore. is there any diagram for how to insert these pulleys correctly?
thanks again
Send it back - they shouldn't be rattling around inside. Not the first time SSS is supplying substandard jacks...
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Oh dear ..
looks like a kit of DIY build it yourself spares ..kit form Jack..
That isn't right ...return it immediately..
Archived-1
Persona non grata
uk
These pulleys should already be in place, @Vipersan has this motor maybe he will post a few pictures up, but falling to bits like that I would send it back.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Mine is a 24 inch ...(not bragging honest)
...and would have to take it off the dish and fully dismantle to get detailed photos of the gearing ..
Naaa ..
that's a return to vendor ..if ever I saw one..
Archived-1
Persona non grata
uk
Yes your right Evan the gearing is behind everything, how have the gears got there?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
The thing is he lives in SA it might cost him a fair bit, take a look here, you might find the pictures needed.
Actuators AGAIN ...
Not sure he will Martin ..
Maybe it's my eyes ..but that looks like the underplate gearbox in bits ..not the top of the plate where connecions to motor/sensor are made..
..Now got me wondering if the OP has opened the gearbox ..and can't now reassemble it ..
Ewwww
Archived-1
Persona non grata
uk
many thanks
Hi unless you have dismantled most of the actuator ? they will be spares, just put them in a safe place and install it as normal.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hi unless you have dismantled most of the actuator ? they will be spares, just put them in a safe place and fit it as normal.
Nice if true Martin ..but since when where manufacturers ever than considerate...as to send a complete actuator and a bunch of spare gears ..
