Hi recently picked up this 36 inch (original I think) superjack as part of the irte package
It is rather rusty inside and upon connecting to vbox gave an instant er2 fault, upon removal of the arm the plastic wheel is spinning and not reporting any faults
The lower section of the arm is jammed solid I assume this would need repacking with grease? there is a bolt in the top with a pin through which I can see connects to the plastic cog wheel
Is this salvageable and if so how do I access the internals of the arm, the end of the arm should twist but is solid
