The palcos still refuse to work, are they seca? is it c+? or tele+??? is it common for these problems to occur after key changes at end/start of month and for channel disruptions to occur for the first few days into the month after a key update??
Some of the providers have changed their "masterkeys".
You will need to use the very latest pic/wafer software for success.
As of yesterday, the "SatTurk" seca software worked 100% (everything open). Today that looks to be struggling with Taquilla, but the rest is still ok.
2old
hi 2old4this, you mentioned changing files but in an early post a few months back (may have been the faq post) you suggested that if you find the files that work then you should keep them and just edit the hex etc with the new keys, if my files are working well which they seem to be except for tequilla this month and palco which i can never get to work then are you saying there is something new or different about the latest files? or should i just try editing again? tequilla were working fine all last month with these files.
in general, you are better off keeping a working file simply becasue they can be temperamental (some work in certain receivers, others don't, etc.)
But providers are starting to get trickier. They are sending false key updates, reset-commands, erasure ECMs, and so on. Each of these tricks needs to be handled within the wafer software or you will lose the channel.
So perhaps for the time being the priority should be to make sure you have the "latest" software...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
