TBS 6925 PCi Card with hardware blind scan in DVB-S2 and DVB-S
what channel have 16apsk ?
remlap
Wales
Found something interesting on 16E which I can't seem to get a steady picture out of
12728 H 6400 32APSK 3/4 DVB-S2
Picture is just green
BlindFaith
TBS 5925
Try next time to capture a sample of the mux and upload it to a file server.
remlap
Wales
BlindFaith
TBS 5925
To me the recording seems broken. I don't have EBS-Pro but from a dump I'd expect the complete mux. 6400kBaud, 32APSK, 3/4 roughly yields 23mbit/s. Your dump has a rate <1mbit/s. Maybe because the tool doesn't capture the null packets (0x1fff). The video/audio parameters can be read wit transedit or mediainfo. The colour of the artefacts seems to depend on the decoder. Lav -green, ffdshow -> grey ;)
remlap
Wales
Thank you, yes its clearly broken, EBS Pro loses signal every so often but the signal is very strong for 32PSK.
vladan10
bigger dish that you can think .
pc card
Southern Europe,Crete
Rai 1
remlap
Wales
Now the question is how do we view it.
BlindFaith
TBS 5925
Good question ;)
You should have noticed in the 1st place that crazyscan reads continuous as stream type and not TS. It has to be transport stream for all known applications.
BlindFaith
TBS 5925
remlap
Wales
Shame thanks for finding and posting that mate.
remlap
Wales
Any reasoning for drivers after .16 are very slow?
I am going to host them here just encase they disappear off TBS's website, remove the file extension .zip leaving 001, 002, 003 at the end and open in 7zip or Winzip.
I've had to compress them this way to get round the 1M limit set by the forum software.
  • tbs6925-windows-driver_v1.0.1.16.zip.003.zip
Still on v.1.0.1.13 here remlap, works fast enough for me.
Can't remember what improvements were in the versions after this, only that which is on the TBS driver info for .16. Could do with the changelog info for the earlier ones.
remlap
Wales
Don't upgrade Llew, CrazyScan seems like a crawl afterwards.
There are complaints about drivers removing low SR scanning as well, but not sure which update introduced that.
remlap
Wales
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
i havent been using the tbs. lately because of building work going on, i am thinking off upgrading to win 7 when i set that computer up again, is there any advantage to using it with 7 rather than xp ?
Don't see what difference there would be, it works fine with my Win 7 64bit OS, and my Linux Mint.
Sent from my Nexus 10 using Tapatalk 4
any idea whether it would work with mac os x? Or do I need dual boot?
Sent from my HTC One X using Tapatalk 4
mephisto
TBS 5925 DVB-S2 TV Tuner USB
Dreambox 500S
Vantage X221S CICX
Samsung DSR 9500 VIACI
Echostar AD 3000 IP
1,2m offset dish w/polarmount
Inverto Black Ultra lnb 0.2 db
Actuator Superjack 12"
55°E - 30°W
Uzice, Serbia
Eutelsat 16A (16E) - 12610 Vertical 1415 16APSK 5/6 DVB-S2 MPEG-4
Tagged as ROU-028
Can anyone please advise me of the file format type output by a TBS 6925 card when recording either SD or HD?
For example, is it a TS file or an MPEG file or a TRP file etc?
Or, is it dependent on the program used for recording?
Rgds
