Tbs6522 problem scan bls2
JDavid22
Parabolic 5.0mts VuZero4k,TBS 5925,6925
Mexico
I have a tbs6522 card that I have not been able to make work as described by many, I have also acquired it because of the support that has been given to it, but I do not know what I am doing wrong when doing a bls2 scan as the tbs6983 does, it does it very quickly and it is very sensitive, obtaining many more tps than the tbs6522, the tbs6522 even hangs in the process or takes too long, I have installed the latest streamreader with the same results, I tried the two drivers on the tbs page 1.2 and 1.5 beta and the results are bad... Could someone help me to optimize my configuration? I have not moved anything from the *.ini file
The 6522 uses a different chip and it's an I2C problem, not an INI file problem
Is this a problem with my motherboard, assuming I can't tweak it in the BIOS? Or is there any other solution possible?
this silabs bug, not depend from drivers or bios settings
After making several attempts, I keep seeing problems, especially in Ku, in C band it works up to a certain point "normal" it is still below my tbs6983 or tbs6925, for the description of the new driver below comes references to driver and firmware (skyworks ) is there anything else to do with this? Thank you
what problems ? not found some ACM transponders ?
The problem is that bls2 is still slow and besides some duplicate tps, this is more common in Ku band scans.
In band C I can say that it works much better.
