Technomate problems.
Atomicbullet
90cm Motorised
Barnsley
Hi guys, it's been a while since i have been on here (normally came on every day to read :p)
Anyway, around 4 month ago i purchased a patched technomate for my motorised system. This worked well for many packages.
Now from what i understand Premier on 19.2 changed their encryption type so keys would no longer work. Im not sure if this has happened or not but..
Other satellite packages all seem to be encrypted, such as on 13.2e or 1w.
So at the moment from what i have tried nothing is unlocked on pacakages/satellites.
Can anyone shed anylight on why this could have happened or if there is something i may need to do?
Thanks.
Thanks.
You need to load a new patch & softcam. There were a few key changes in Dec for 1W.
Thank You for your reply, i have had a quick google and not had any good results. I will carry on looking though, but do you know of any sites that hold the files and instructions. Do i have to pay for them?
Thank You.
Thank You for the link, Just looked through down to Technomate and also had a quick search and cannot find any software that has the patch/keys included etc..
Go to the non-official link, a l s a t.co.uk, you will need to register to see the files.
Thank You, i found the file and loaded i onto a memory stick. The next problem comes, I am 99% sure i did not change the password. I have tried ones like 1234, 0000, 1111,2222, etc.. and also tried any and the only digit codes i would use and still not managed to find it.
Any idea what i could do or am i stuck now?
Thanks.
Thanks.
everything you need to know is on (***** ) google it software, patches key and comprehensive technomate user guide, just register, scroll to the technomate section and start with ''everything you need to know about '' section
Thanks.
2011 will do it.
