technomate tm-1500 ci+super. problem
mariust5
Cristor Atlas 100HD , motorised 1.1 Triax on Stab H-H
hastings , uk
Hi there
Well i dont know what's wrong with it , but after i watch it a couple of hours it doesn't respond to any comands anymore and i have to reset it from the front buttons Power+Up for 5 seconds .
Only the on off command responds . Can anyone tell me what's going on please ?
Model= tm-1500ci+super
sw version = 1.53 ( jan 10 1006 )
hw version = 1.11
boot version = 2.10 (08:10 )
ch version = dec 05
ThanksI hope this is the right place to put this thread , i can't find anywhere for receiver problems.
Sounds like you are trying to view a m****vision channel, if this is the case then I have the same problems, this was happening before the last patch update so it looks like we need another software update.
Yes , i tried to watch m vision but then i did do a factory reset and reloaded a earlyer soft version and it does the same .
I'm wandering if it's anything to do with my setup as i have it looped through 2 other receivers , echostar dsb2200 and hyundai hss-1120 , but again i tried without loop and it does the same .
It also could be a heat problem .
I dont know what to do anymore.
Hi, there
I've got same problem , my receiver technomate 1500 ci+ super update by him self , new wrong key every day even i change them with a new key, still same ....................I think we have to change a new software ...
I think i've sorted mine , it was the scart lead ( i hope ) , changed everything on it until i got to the last option , the scart lead , it's been working ok all day now , no problems whatsoever .
Who has similar problems , try to change your connections , u never know .
I'll let u know if any changes .
Thanks for your support .
Yeah, had probs with scart in top hole , remote not workin, sluggish... read elsewhere was a problem!!!!
mariust5 said:
it was the scart lead, try to change your connections ,
Hi mariust5, Did you get a new scart lead and if so what type, or was it just a case of plugging it back in again.
Hi sorry for the late reply , just changed it with a similar one , nothing fancy . It's still ok just =i tried to set up a motor with it , a technomate stab 120 usals i think , put a scaffold pole vertical and then the dish and the motor toghether on it . Now , i got a strong signal on thor 1* west and when i tried to move the motor with the move west command from the receiver it moved in very short litlle steps backward and forwards like a yoyo . A few times it moved like i wanted it to but most of the time it didn't . Is this normal or am i doing something wrong ?
I must mention that the receiver has the 21-01-2006 patch and the temperature outside was 0 degrees
hi mate i live in hastings you can borrow my sat meter as you said you havnt got one.
Welcome to the forum tagura
Well that is extremely kind of you tagura but hopefully mariust5 has sorted the problem he had 20 months ago ;)
