technomate
live2dmax
Hi ,
I have a technomate 5500d and i want to know if i can watch any encrypted channel ,sys. is motorised as well.Can get a lots of channels and many are scrambled.Help please,
live2dmax said:
Hi ,
The 5500D does not have a CI slot. You need a 5500CI to take a cam & card to enable decrytion of scrambled channels.
There are certainly non-standard software patches for some of the Technomates, just having a look to see if there is one for the 5500D. Of course the standard cautions apply when uploading modified firmware.
So,wich receiver it will be the best (f.e. easy to upgrade ,easy to patch) for watching movies (like taquilla f.e.). not to expensive!
Depends on what you consider not too expensive, but I favour the Dreambox range, the 5620 is a nice little receiver at a good price.
Hello i have a tecnomate is chanells the cut the
codes can u help
:D Hello there!!! Can anyone pleeease tell me what is the best card for viewing multivition, tps and discovery channels on Hotbird?
My receiver is Technomate 5500 CI. And I have got a Matrix Revolution CAM.
Thank you!!!!
Just love the way Hijacking appears
@ john_graydon
Sign of the times m8, happening more and more on all of the boards, same as not posting "please" or "thank you".
Best to ignore a hijack and then they might learn to post properly (hopefully).
